XQSHEN
6 years agoproblems find when simulate UniPHY + DDR2
IP: UniPHY with DDR2 controller
Quartus Prime Standard 18.0
Simulation: Nios 2 + Uniphy + Micron DDR2 (MT47H128M16)
Modelsim-intel is used.
Problem: it stops during ddr2 initialization phase....
- 6 years ago
Hi Xiaoqiang Shen,
UniPHY simulation does not adhere to the initialization timing to speed up the simulation so it will fail when using the Micron memory model. I assume the simulation passes with the DDR2 example design with Intel generated memory model. As a workaround, you can comment out the initialization time check in the Micron memory model.
Hope this helps.
Rashmi
IntelSupport
Contributor
6 years agoDoes this latest sim run much longer than the previous simulation? It should be running full calibration
Can you please check how long mem_reset is asserted? It should stay low for at least 200usec in full calibration mode
