problems find when simulate UniPHY + DDR2
- 6 years ago
Hi Xiaoqiang Shen,
UniPHY simulation does not adhere to the initialization timing to speed up the simulation so it will fail when using the Micron memory model. I assume the simulation passes with the DDR2 example design with Intel generated memory model. As a workaround, you can comment out the initialization time check in the Micron memory model.
Hope this helps.
Rashmi
I used +define+ALTERA_ALT_MEM_IF_PHY_FAST_SIM_MODEL=0 in related files nios_mem_if_ddr2_emif_0_p0.sv and nios_mem_if_ddr2_emif_0_pll0.sv.
And modelsim shows message: # Using Regular core emif simulation models.
But it still doesn't work.
- Rashmi16 years ago
Does this latest sim run much longer than the previous simulation? It should be running full calibration
Can you please check how long mem_reset is asserted? It should stay low for at least 200usec in full calibration mode
- XQSHEN6 years ago
It stops at the same position. Nothing changed.
