XQSHEN's avatar
XQSHEN
6 years ago
problems find when simulate UniPHY + DDR2
IP: UniPHY with DDR2 controller Quartus Prime Standard 18.0 Simulation: Nios 2 + Uniphy + Micron DDR2 (MT47H128M16) Modelsim-intel is used. Problem: it stops during ddr2 initialization phase....
  • IntelSupport's avatar
    6 years ago
    Hi Xiaoqiang Shen,
    UniPHY simulation does not adhere to the initialization timing to speed up the simulation so it will fail when using the Micron memory model. I assume the simulation passes with the DDR2 example design with Intel generated memory model. As a workaround, you can comment out the initialization time check in the Micron memory model.
    Hope this helps.
    Rashmi
