Problem with Fitter LL Ethernet 10G R core rx/tx_serial I/O
Hallo,
I'm using the LL Ethernet 10G R core from Intel.
When I use the sample design it works fine.
When I start adding more functions after a while the fitter (Quartue 21.2/3)gives me this error message:
Extra Info(13133): Output port's "VOP[0]" node name is "ethernet_top_top_0|CNL[0].wrapper_inst|baser_inst|xcvr_native_a10_0|g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_pma|gen_twentynm_hssi_pma_tx_buf.inst_twentynm_hssi_pma_tx_buf".
Extra Info(13134): Input port's "DATAA[0]" node name is "tx_eth_serial_data[0]".
Extra Info(12877): Output port "VOP[0]" of "HSSI_PMA_TX_BUF" can connect to:
Extra Info(12878): Port "IN[0]" of "IO_OUTPUT_BUFFER".
Extra Info(13133): Output port's "COMBOUT[0]" node name is "rx_eth_serial_data[0]".
Extra Info(13134): Input port's "RX_P_BIDIR_IN[0]" node name is "ethernet_top_top_0|CNL[0].wrapper_inst|baser_inst|xcvr_native_a10_0|g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_pma|gen_twentynm_hssi_pma_tx_buf.inst_twentynm_hssi_pma_tx_buf".
Extra Info(12879): Input port "RX_P_BIDIR_IN[0]" of "HSSI_PMA_TX_BUF" can connect to:
Extra Info(12880): Port "OUT[0]" of "IO_INPUT_BUFFER".
Extra Info(13134): Input port's "RXP[0]" node name is "ethernet_top_top_0|CNL[0].wrapper_inst|baser_inst|xcvr_native_a10_0|g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_pma|gen_twentynm_hssi_pma_channel_pll.inst_twentynm_hssi_pma_channel_pll".
Extra Info(12879): Input port "RXP[0]" of "HSSI_PMA_CDR_PLL" can connect to:
Extra Info(13134): Input port's "RXP[0]" node name is "ethernet_top_top_0|CNL[0].wrapper_inst|baser_inst|xcvr_native_a10_0|g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_pma|gen_twentynm_hssi_pma_rx_buf.inst_twentynm_hssi_pma_rx_buf".
Extra Info(12879): Input port "RXP[0]" of "HSSI_PMA_RX_BUF" can connect to:
Error(11216): Output port "VOP" of "HSSI_PMA_TX_BUF" cannot connect to PLD port "DATAA" of "LE_COMB" for node "tx_eth_serial_data[0]".
Error(11215): Input port "RX_P_BIDIR_IN" of "HSSI_PMA_TX_BUF" cannot connect to PLD port "COMBOUT" of "LE_COMB" for node "rx_eth_serial_data[0]".
Error(11215): Input port "RXP" of "HSSI_PMA_CDR_PLL" cannot connect to PLD port "COMBOUT" of "LE_COMB" for node "rx_eth_serial_data[0]".
Error(11215): Input port "RXP" of "HSSI_PMA_RX_BUF" cannot connect to PLD port "COMBOUT" of "LE_COMB" for node "rx_eth_serial_data[0]".
Error(16297): An error has occurred while trying to initialize the plan stage.
I started several times from scratch but after a while I get this error message and I found not way to return.
regards
Michael
