Problem W/ Altera VIP Frame Buffer II
I have configured an FPGA design for my linux device that is displaying SDI and HMDI inputs. It was originally configured to receive YCbCr 4:2:2 video format. Since I am experiencing green spill on images when trying to chroma key, I am attempting to change the input data to RGBA.
For a test, I have implemented a conversion into the FPGA that handles the RGB input from the frame buffer. I believe this conversion is correct because the color values come out as expected.
FPGA Design Here:
FB -> CSC -> CRS -> Output
This is the same for all four mixers.
I am using gstreamer to input the color bars pattern into the pipeline.
(gst-launch-1.0 videotestsrc ! videoconvert ! video/x-raw,format=BGR,width=1920,height=1080 ! videoconvert ! filesink location="/dev/fb3")
There are 4 frame buffers located at "/dev/fb0", "/dev/fb1", and so on.
Basically the issue is these frame buffer's graphics are overlapping and changing the memory regions in the DTS file does not fix the issue:
"gst-launch-1.0 videotestsrc ! videoconvert ! video/x-raw,format=BGR,width=1920,height=1080 ! videoconvert ! filesink location="/dev/fb0"
"gst-launch-1.0 videotestsrc ! videoconvert ! video/x-raw,format=BGR,width=1920,height=1080 ! videoconvert ! filesink location="/dev/fb1"
"gst-launch-1.0 videotestsrc ! videoconvert ! video/x-raw,format=BGR,width=1920,height=1080 ! videoconvert ! filesink location="/dev/fb3"
I can even see the bottom portion of the color bars pattern when changing the height to 720.
"gst-launch-1.0 videotestsrc ! videoconvert ! video/x-raw,format=BGR,width=1920,height=720 ! videoconvert ! filesink location="/dev/fb3"
The drivers being used for the frame buffer is altvipfb.c and altvipfb2-plat.c
Here is the DTS snippet of these frame buffer components and the boot logs where the frame buffers are initialized:
DTS snippetBoot Logs
The virtual address and length seen in these boot logs do not change at all when DTS changes are made.
I also get this error when inputting a pipeline:
If anyone could help me approach this issue it would be greatly appreciated.
Evan
