FHint
6 years agoProblem erasing a Micron Flash using the Generic Serial Flash Interface IP
I am using the GSFI to access a MT25QU256ABA flash in order to write and erase FPGA images, that will be loaded via the Remote Update IP.
Writing and erasing JIC files with the Programmer/...
- 6 years ago
Yes, you need to performed it to before every erase.
JohnT_Altera
6 years agoH,
May I know if you performed write enable to the flash?
FHint
6 years agoHi,
yes, I performed a single Write Enable (command = 0x06) to the flash before the first Sector Erase.
Do I need to do that previous to every erase?
