16 years ago
Problem : DSP builder simulink block installation into MATLAB simulink.
Dear friends,
I am working on image proccessing project for that, i need to install DSP builder simulink block into MATLAB simulink.
I have license version of altera 7.1 suit and MATLAB R2009b.
I tried 4-5 times to install both.
In first trial, I installed MATLAB first and than DSP builder.
In second trial I installed DSP builder first and than MATLAB.
But problem is that its' blocks are not shown into simulink every time.
Once I formatted my PC,too. But it didn't work.
I read installation guide of DSP builder and run command 'alt_dspbuilder_setup_megacore'
in MATLAB, but it didn't worked.
I read installation guide of DSP builder.It says that you need to make matlab folder READ only. but how it possible to make it read only,if I first install DSP builder?
Give my clear way for DSP builder installation.
Ronak Shah.
    You need to start MATLAB through the "dsp_builder.bat" file inside the dsba folder
    i've got the same problem and i sloved it just now. you can try this: in window os,start->all programmer->altera->dsp builder->start in matlab 20XXX.then you may see the dsp builder library.
    good luck
