Platform Designer HDL generation errors on AN 830: Intel FPGA Triple-Speed Ethernet and On-Board PHY
- 6 years ago
I found a workaround of this problem, please unzip the attached file to get the two missing folders (crc32 & User_Logic), and then locate it at "platform" folder. After that, you should be able to generate the platform designer of this example.
Regards -SK
hi,
Thank you for letting us know this problem, and I can observe the same error from my site.
It look like the hw.tcl files for those customer components in this design was not included in the par file. I will contact the owner of this design to obtain those missing files. Will keep you updated.
Regards -SK
- SengKok_L_Intel6 years ago
Regards -SK
- Lorne_K_Intel6 years ago
Thanks, SengKok.
The solution works perfectly.
