FPGA_World
5 years agoPFL IP core causing Flash access error
I am Interfacing Intel FPGA Cyclone V (5CEBA5F), MAX V CPLD (5M1270Z) with Flash (S29GL01GT) to configure and store data.
I am using CPLD and Flash device to configure the FPGA. In CPLD, I have imp...
- 5 years ago
To reach the solution, I tried following solutions
1) Init_done signal from FPGA is feedback to one of the FPGA's input pin and enable all the FPGA logics AFTER "Init_done" is high.
2) Reset the Flash device after Init_done is high and before writing data to Flash.
3) Use "Flash_ready" signal to verify the Flash state after reset.
I hope this helps.
NurAiman_M_Intel
5 years agoHi,
You may refer to PFL IP userguide below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf
Aiman
