EMOEN
6 years agoPCS bonding channels must be locked in ascendning and continous order.
Hi, I am currently trying to compile the "Intel FPGA HDMI IP" for an Achilles Arria 10 Instant Dev kit. I am using the Inrevium HDMI 2.0 FMC card. After filling in the pinout i get the following er...
Deshi_Intel
6 years agoHI Espsea,
After reviewing your design and compared with HDMI example design again, I found out your design HDMI pin placement is in DESCENDING order, not in ASCENDING order as required by PCS bonding. Attached is the diagram showing you the difference
That's explain why fitter compilation failed.
I have tested. Once you reverted your design HDMI pin placement from descending order back to ascending order then fitter compilation will pass.
dlim
