AndyRea
4 years agoPCIE surprise removal BIOS crash when reprogramming
using an Arria 10 with Hard PCIe engine for a DMA application with Ubuntu 20.x Linux as the host OS
when the card is in a newish HP machine, re-programming the FPGA through JTAG once installed and ...
SengKok_L_Intel
4 years agoYou may use the setpci command, below is the example code, and you need to do it by using the right BDF in the PCIe tree topology.
sudo setpci -s 86:00.0 ECAP_AER+0x08.L=0xffffffff
sudo setpci -s 86:00.0 ECAP_AER+0x14.L=0xffffffff
*86:00.0 is the BDF
