Serge93
11 months agoPCIe reset stuck on Arrow Eagle board
I am doing an NVME Host IP to drive SSD NVME. I'm using an Arrow Agilex-5 EAGLE Board with Device A5ED065BB32AE4SR0 with Q25.1.1 I have connected on the PCIe Edge the AB19-M2PCI board on which...
RongY_altera
Contributor
11 months agoHi,
According to the pin connection guide, the unused PERST pin for the same GTS bank must be left floating.
Your PIN_CF132 and PIN_BU109 are on bank 5A and 5B, respectively. You may check the remaining PERST pins on these two banks.
Rong
- Serge9311 months ago
Hello Rong,
On the Arrow Eagle board :
The PIN_CF132 (PCIE_PIN_PERST_N in GTS PCIe IP) is connected to the PERST# pin of the PCIe edge.
The PIN_BU109 (PCIE_PIN_PERST_N_I in GTS PCIe IP) is left floating.
I do not understand clearly what you mean by "You may check the remaining PERST pins on these two banks."
Please see attached the schematic of the Bank 5A and 5B :
Please let me know what I have to check exactly.
Serge
