PCIe-MM-DMA: Read/Write DMA & BAR0/2 mutually exclusive?
Just want to understand the problem that you are facing is write-DMA left pending for a long time. Or you are unable to perform the other activity before the write-DMA complete.
If the first one, then may I know how long it left pending? I guess maybe this is due to the FC setting.
If the second one, then I think it is expected behaviour. We need to wait for the write-DMA to complete before we can perform other operation.
Thank you for your reply.
It's the second case where I'm unable to perform the other activity before the write-DMA complete.
Is this a limitation of PCIe in general? Or is it possible to customize the IP Core's Descriptor Controller (when generated externally) to allow concurrent Read/Write-DMA and BAR0/2 activities?
Ari
