CLeon14
6 years agoPCIE IP nINIT_DONE signals.
I am using Stratix10 PCIE IP I change to a newer Quartus version 19.4 pro and I found there is additional input signal for this IP. The signal name is ninit_done. Where should I connect this signal?...
SengKok_L_Intel
6 years agoHi,
You can find the ninit_done signal (output signal) from the Reset Release Intel FPGA IP. You need to instantiate this IP in your design to reset the user logic.
Regards -SK
