FFULC
5 years agoPCIe Hard IP core in Cyclone V GX
I am using a Cyclone 5CGXFC5C7F23C8N in a new design and planning to implement a PCIe x4 endpoint with CvP enabled.
The CVP user guide, UG-01101, states that I need to use the bottom left hard IP w...
FFULC
5 years agoHi John
I have shown you the screenshot before but can I use REFCLK1 as an alternative PCIe clk? REF_CLK comes on to our board through a backplane from the Root Complex. If we have signal integrity issues then I'd like to connect a local 100Mhz LVDS clock to REFCLK1. Will this work?
Frank
JohnT_Altera
5 years agoHi,
If you are using the bottom Transceiver then you can only use REFCLK0.
