FFULC
5 years agoPCIe Hard IP core in Cyclone V GX
I am using a Cyclone 5CGXFC5C7F23C8N in a new design and planning to implement a PCIe x4 endpoint with CvP enabled.
The CVP user guide, UG-01101, states that I need to use the bottom left hard IP w...
JohnT_Altera
5 years agoHi,
If you look into the note "The E64 package has an exposed pad at the bottom of the package. This exposed pad is a ground pad that must be connected to the ground plane on your PCB. ". So you are only connecting the exposed pad to GND and the not mention pin is NC.
- FFULC5 years ago
Hi John
I have shown you the screenshot before but can I use REFCLK1 as an alternative PCIe clk? REF_CLK comes on to our board through a backplane from the Root Complex. If we have signal integrity issues then I'd like to connect a local 100Mhz LVDS clock to REFCLK1. Will this work?
Frank
- JohnT_Altera5 years ago
If you are using the bottom Transceiver then you can only use REFCLK0.
