FFULC
5 years agoPCIe Hard IP core in Cyclone V GX
I am using a Cyclone 5CGXFC5C7F23C8N in a new design and planning to implement a PCIe x4 endpoint with CvP enabled.
The CVP user guide, UG-01101, states that I need to use the bottom left hard IP w...
JohnT_Altera
5 years agoHi,
The recommended flash in the document is if you are planning to use remote update system which is to store at least 2 full bitstream. If you are just using planning to use CvP where you are only storing IOCSR bitstream then you can use the smallest flash device.
- FFULC5 years ago
Thanks John
I have created the bigger EPCQ128A SOIC-16 part in our database now so we can use it for future projects.
But it will work with this part or the footprint compatible EPCQ64A?
Frank
