FFULC
5 years agoPCIe Hard IP core in Cyclone V GX
I am using a Cyclone 5CGXFC5C7F23C8N in a new design and planning to implement a PCIe x4 endpoint with CvP enabled.
The CVP user guide, UG-01101, states that I need to use the bottom left hard IP w...
JohnT_Altera
5 years agoHi,
The transceiver pin looks good to me. You will need to use nPERSTL1 pin as this is the use for CvP.
- FFULC5 years ago
Thank you John.
I am now looking at what config scheme is best for me alongside CvP.
I am planning to use AS x4 with a EPCQ device for the periphery image for my Cyclone V GX, as below:
I have 2 questions:
What is the best way to program the EPCQ? I want to use the ByteBlaster interface, do I need to connect it to the AS interface rather than to the Cyclone's JTAG pins (via SFL bridge) when using CvP?
Also what size EPCQ part can I use?
