PCIe DMA Testbench Generation Issue
- 6 years ago
Hello Sir,
The reason is that you export the master port of the clock crossing bridge. And the BFM in default will generate the address 32bits. What you need to do is add the BFM slave manually and set the address to 30bits. And turn on the burst on burst boundaries only option. Then connect the CC bridge and the BFM slave clock and reset from the system. With this. The testbench can generate correctly. Attach the modified qsys file.
Hello Sir,
- Sudhirkv6 years ago
Thank you for your response. We added the Avalon-MM slave BFM and set the parameters as advised by you and we were able to successfully create testbench system for the design.
We could see a read transaction in the Avalon MM slave BFM but the Read response is always driven as X. Attached is the screenshot for the same. Could you please let us know how to proceed with this?
I will also add the QSYS file of the design for your reference.
