LKrup
7 years agoPCIe device not detected after programming CVP peripheral core
I have Reflex Attila Arria 10 GX (chip is Engineering Sample) board with simple PCIe test project on which 'lspci' command shows Altera device. I proceed with instructions in ug_a10_cvp_prop.pdf and ...
Nathan_R_Intel
Contributor
7 years agoHie,
I am suggesting to program full .sof file using either JTAG or through Flash (JIC file).. You do not need to use CvP. You can access the signaltap using JTAG connection.
Nathan
