LKrup
7 years agoPCIe device not detected after programming CVP peripheral core
I have Reflex Attila Arria 10 GX (chip is Engineering Sample) board with simple PCIe test project on which 'lspci' command shows Altera device. I proceed with instructions in ug_a10_cvp_prop.pdf and ...
LKrup
7 years agoI could be wrong but until CVP logic core is not programmed all user logic can't work because it not configured, and Signaltap works on internal block RAM and user logic so I can’t use it. Correct me if I am wrong.
