14 years agoPCIe bus master random access to all host memory
I'm not sure if the PCI Express MegaCore hard IP can do what I want. I'll describe what I'm trying to achieve. I'd like to set up a bus-master scatter-gather DMA between on-device memory and a ...
14 years ago --- Quote Start --- I'd like to set up a bus-master scatter-gather DMA between on-device memory and a host memory buffer. The host memory buffer is contiguous in virtual address space, <...> I'm not sure how this fits in with the Avalon-MM-to-PCI Express address translation table.<...> --- Quote End --- That's perfectly possible. You do not need any (BAR) translation table on the FPGA, because the FPGA is doing SGDMA directly to/from host memory, so there is no BAR access involved. For a ready to go SGDMA solution with drivers, see http://www.lancero-pcie.com/ Best regards, Leon Woestenberg
