PCIE avalon MM DMA in Arria 10 FPGA
I want to use PCIE Avl DMA in Arria 10 device. However, when I open the Intel Arria 10/Cyclone 10 Hard IP for PCIE in IP catalog. After open the interface, in the field of Application interface type, only can see Avalon ST and Avalon ST SRIOV in the selection. How to use PCIE Avl DMA in Arria 10?
- SengKok_L_Intel
This is available at the Platform designer -> IP catalog -> Interface Protocols -> PCIe express -> Intel Arrai 10/Cyclone 10 Hard IP for PCI express
Regards -SK
- CLeon14
Thank you. Any Idea it is no available in Quartus IP catalog? I want to use the IP but I do not want to use the platform designer.
- SengKok_L_Intel
For AVMM interface PCIE IP, this is suggested to instantiate from the Platform design so that it can easily connect with other components which are also AVMM interface. You can export all signals of PCIe IP out from the Platform Designer if you don't wish to use it there.
