PCI Express High Performance Reference Design AN-456 on Cyclone IV - Hangs PC on boot?
- 7 years ago
Thanks for your reply. Yes, your understanding is correct.
OK we have just found the issue! 😀
The problem was caused by the BAR 0 register being 256MB in size. Apparently some BIOS don't like the fact that it's so large. We were trying this on an older Dell PC, which didn't like it. When we reduced the size of the BAR 0 register down to 64kB it worked fine. After this we tried the original 256MB in another newer PC and it worked fine.
Thank you for your advice to look at the LTSSM register on the Signaltap, we did look at that and saw that it was reaching state L0, which then led us to find the BAR 0 memory size problem.
Cheers,
Matt
Cheers,
Matt
