PCI Express Hard IP on Cyclone 10GX: BARs using I/O space and debug questions
Hi ,
Keeping the post in public.
May I know which PCIEe IP you are using is it Avalon MM Avalon ST.
It's Avalon MM.
- Rahul_S_Intel16 years ago
Kindly find the inline answers for your question.
Question no:1
It is not possible to se the I/O address space in Cyclone 10 GX and for your info the I/O address space is only supported in Legacy endpoint . The Legacy endpoint is only supported in certain variants of Arria 10 devices Avalon ST configuration.
Below is the error you will get from qsys when you select the I/O address space.
Error: pcie_a10_hip_0: The current value "I/O address space" for parameter "Type" (bar0_type_hwtcl) is invalid. Possible valid values are: "Disabled" "64-bit prefetchable memory" "32-bit non-prefetchable memory". The parameter value is invalid under these current parameter settings: "Port type" (port_type_hwtcl)="Native endpoint". Rule(s): bar0_type.
Question:2
For debugging the PCIe , we have an step by step documentation, in the below link. If you could not able to access the link kindly let me know.
Hi ,
May I know still you need support
- NWein6 years ago
Well, it's still not working. Unfortunately, my attention has been divided among a bunch of different issues so I haven't been able to concentrate full time on any of them.
I'll provide an update on this tomorrow.
