PCI express Arria II GX problem
In my final FPGA design for Arrria II GX (EP2AGX65) I need to use 2 instances of PCIe Core (because of our dual-star backplane topology), and Arria II GX has only one HARD IP PCIe.
So, it would be better to find final solution for SOFT IP PCIe Cores, and not one solution for HARD IP and another for SOFT IP.
When it is possible to have Avalon-MM interface in HARD IP, why is not possible to have it in SOFT IP? Really Intel does not have any component, that translate PCIe TLP´s packets from Avalon-ST interface into Avalon-MM interface? How does it make in HARD IP, it has to be similar. In the HARD IP does the solution exist, how is it done there?
There is no embedded component/bridge that can support pcie avst-to-avalon_mm conversion.
Arria II GX is a legacy device and the avmm interface support in rootport mode/soft IP is limited.
