BrianWissel
5 years agoParallel Flash Loader
We are using a MAX10 to configure an Arria V, serving as the bridge between Arria V and the 4 memory devices. I have noticed the fpga_nconfig is not being pulled low to initiate configuration but th...
- 5 years ago
Yes, you are right.
YuanLi_S_Intel
5 years agoHi Brian,
Are you referring to Arria V's nCONFIG pin right? As per the user guide, it needs to be pulled high for configuration.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-v/av_5v2.pdf *Page 280)
Thank You
- BrianWissel5 years ago
YuanLi_S,
Yes I am referring to the Arria V nConfig pin.
I just want to confirm correct operation as the nConfig pin is never "released" high by the PFL engine, rather it rises with the power supply and stays high. I just want to confirm that this is correct, reference my attachment in my original post.
Brian
