Gyud0
6 years agoParallel Flash Loader IP - mapping ports problem
hey, I was creating the Parallel Flash Loader IP by Quartus MegaFunction. I integrated this IP in the Top design file( add the IP's ports, declare the IP, mapping the IP to the Top's port). Then I ...
NurAiman_M_Intel
6 years agoHi,
I believe my previous response has address your question since there is no update on this case. Hence i will proceed to close this case, but please noted you can re-open this case within 10 days or create a new case if you need further information.
Thank you.
Aiman
