OTA configuration process on Cyclone V FPGA via QSPI flash
Please find my response below:
1] for using this IP do we need to connected external flash memory to dedicated AS configuration IO on Cyclone V FPGA for QSPI flash
Yes, you need to connect QSPI flash with it.
2] what is max frequency at which we can run this IP and configuration?
20MHz for Cyclone V.
3) Error (169310): Design has remote update block "axi_control_block:axi_control_block_i|spi_recievers:spi_recievers_i|spi_recievers_remote_update_0:remote_update_0|altera_remote_update_core:remote_update_core|sd1", but the selected configuration scheme "Passive Serial" does not support remote update
It seems like you have selected "Passive Serial" in the setting? Can you change it to “Active Serial”?
“tools -> Device and Pin Options -> Configuration -> Configuration Scheme”
