On-Chip Flash IP can Erase but not Write
Do you make sure to erase the flash location before you perform a program (write) operation?
Do you able to duplicate the figure no. 8 diagram in the UG?
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_ufm.pdf#page14
You can refer to the example design below from the link below.
https://fpgacloud.intel.com/devstore/platform/17.1.0/Standard/max-10-user-flash-memory-write-operation/
Yes, I make sure to erase the flash location before writing.
In my original design I did not hold the write signal for long, though after modifying the code, writing still fails.
I'll work off the example design, I couldn't find that from the design store.
Thank you.
- RichardT_altera6 years ago
Try again with the design store. The link should be fixed by now.
