AMoha31
7 years agoNot able to generate HDL because of tight clock constraints -Altera DSP builder
I am trying to develop a Simulink model of electric machine with DSP builder advanced blockset. This model will be later used to generate HDL code and loaded into Vector VT System FPGA (Altera Cyclen...
AMoha31
7 years agoHi KYeoh,
I tried to reduce the clock speed but it gives the same error.
Once I reduce the clock speed below 20 MHz it gives different error - Failure to redistribute delay in [IM_Test_User_FPGA] - negative cycle.
Thank You
