No output from FFT IP
Thanks for sharing the QAR. As I look into the design, I understand that you are using Max10 and there is a NCO feeding data to FFT. You are using counters to control the SOP/EOP.
When look into your FFT configuration, I notice the following:
1. Length = 128. If I remember it correctly, you mentioned that you are feeding 1024 samples. Not sure if this is something expected? If not, try setting to 1024.
2. Representation = Block Floating Point. Can you try with Fixed Point.
Chee Pin
- JWall406 years ago
It works!!!! Thank you very much :)
The length was intentional, I reduced it so I could see more cycles using signal tap without using up all my resources.
Changing to variable streaming and then fixed point solved the problem. Why does fixed point representation solve the problem? Is it something to do with the Max10 family?
Many thanks and best regards
Jack
