13 years agoNew IP development
Hello, I am interested in developing some instructions which can do the bignum operations (like adding two operands of 1024 bit) and hence by plan to implement a simple Full Adder like this: ...
13 years ago --- Quote Start --- This thread is almost ( but not quite ) gone full circle.:p With pure software optimization, I guess you would be looking at an ideal goal that boiled down to (64) loads for the two operands, (32) add/subtract/whatever, and (32) store of the result. Let's call it 128 instructions. If you are not a HDL person, and this ideal performance is more than adequate of where you need to be, you can attack your problem with just software and at least have a chance of achieving your desired performance. --- Quote End --- Akhil>> Please note that this is an academic thesis project and hence by I plan to implement hardware modules for RSA and BIGNUM which could assist an application developer (who may program in a NIOS II SBT, in C/C++). It is not the other way around, which can make a circle as you pointed out :P. I have an example code with me which does the software implementation for RSA. I was wondering any means of converting the software implementation to an HDL RTL design and comparing the performances. And please remember my tentative design diagram, that is not a finalized one. As of now I plan to generate the primes for RSA inside my RSA IP core and hence by I may not have to load the NIOS II CPU for that. Also the communication between the RSA <-> BIGNUM should be okay (I guess?) since I plan to make both the data buses as 1024 bits (even the ALU s). --- Quote Start --- The shortcoming of C2H in this specific example is that I believe it is structured as an optimization tool for 32-bit operations, and there is no way to communicate to it that you want to specify 1024-bit operations. --- Quote End --- Akhil>> The C2H has been discontinued for QSYS and as you pointed out, that is specific for NIOS II, which supports a 32-bit architecture. So I may not be using this to convert my C to a hardware accelerator. --- Quote End --- --- Quote Start --- Back to the current topic of software optimization: I think what you want to do is use the profiler to identify your high execution count / execution time functions, and then techniques like dsl has written to zero in on the big bottlenecks. As far as acquiring timing data, I like the Performance Counter IP block. --- Quote End --- Akhil >> I am interested to profile my code for finding out the bottlenecks. However the challenge here is to convert my C code to a hardware efficiently after identifying the bottlenecks in the code. Please advice me if you know an efficient tool or if I have to hand-code everything. Best, Akhil Kalathungal
