13 years agoNew IP development
Hello, I am interested in developing some instructions which can do the bignum operations (like adding two operands of 1024 bit) and hence by plan to implement a simple Full Adder like this: ...
13 years agoHello,
Off late, I am asking a question which I should have asked some time before. I have seen the way an application code can be accelerated using the C2H compiler at the link http://www.altera.com/literature/ug/ug_nios2_c2h_compiler.pdf This looks like a promising approach since I have the application code for RSA handy with me and I have to identify the bottlenecks (may be I can use the code profiling method). So, instead of developing a handwritten IP core design and verilog hardware, will it be a good approach if I can use the C2H compiler for the hardware acceleration? I am not a great programmer in Verilog, however I am okay in C/C++. One trade off I see here is, the C2H compiler cannot create accelerator for QSYS systems, it works only with the SOPC builder. Is there any altera gurus who can comment on the above concepts and trade-offs, that would be a huge help before I kick start the real implementation. Best, Akhil
