Need to know the cost of licensing the Intel VIP color plane sequencer IP
The license can be quite expensive for a one-off project that does not go to production. Probably thousands of dollars in this case. It looks like the evaluation flow would be more appropriate for your needs. The evaluation flow can be used to generate time-limited device programming files. In the case of the VIP IPs, there should also be a tethered mode which would allow you to run a design indefinitely if you maintain a JTAG connection with a host PC running Quartus.
Information on the evaluation flow and how to purchase a license (you will need to register and probably talk to someone if you really need a license):
https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/megacore-ip.html
The video IP user guide should also contain information regarding the licensing and the evaluation flow.
- CKOCH27 years ago
Hi vgs, thanks for the good info!
Tethered evaluation mode doesn't want to play nicely with linux running on the HPS, but perhaps if I keep poking around other forums I'll find someone who's done something similar.
Funny enough, I did try talking to someone, but always seem to end up the same place: right here in this forum!
