8 years ago
NCO Simulation help
I am new to FPGA/VHDL and I am trying to generate a sine wave using the Altera NCO IP Core. I have instantiated the IP component and I am using the test bench generated. When I try and simulate the design using modelsim I get numerous errors similar to the one below:
Error(suppressible): (Vsim-10000) nofile(39): unresolved defparam reference to 'acc' in acc.lpm direction.
Time : 0 ps iteration: 0 instance: /sine_ip_core/uo/nco_ii_0/ux000 File: nofile.
Does anyone have any suggestions to solving this issue?
Any help would be appreciated.
Kind regards
    1.Are using tcl scripts for setting up model-sim?
    I have tried to simulate it is working. with the help of tcl script generated and few comments.
    Can you share the screen short of the error.
    Attached model-sim transcript log file for reference.
    Anand Raj Shankar
    Thanks for your response.
    I am simulating by setting the test bench file in Alteras simulation settings and then clicking Tools -> Run Simulation Tool -> RTL simulation. This prompts modelsim and then I get the following errors:
    https://www.alteraforum.com/forum/attachment.php?attachmentid=14621
    I have not encountered using TCL scripts to simulate as of yet...
    Kind regards
    The NCO core files are encrypted and can't be used by Modelsim. You need to generate a dedicated simulation model and - as I guess - import it manually in your simulation project.
    --- Quote Start ---
    Kind regards
    --- Quote End ---
    1.While generating system(NCO), have you enable simulation?
    So that you can use scrip for loading the libraries which is easy to do.
    Refer the doc for steps:
    Anand Raj Shankar
