RDobk
7 years agoNCO IP Core Reset_N and CLKEN functions
Hi, What are the requirements for Reset_N and CLKEN timing? Is there any minimal width for RESET_N in terms of clock cycles? Should assertion of CLKEN always precede the RESET_N de-assertion (res...
Rahul_S_Intel1
7 years agoHi,
I am requesting to go through the below document, and in that if you are
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_nco.pdf
The RESET_N signals are asynchronous signal.
RDobk
7 years agoHi,
I am familiar with this document.
Unfortunately, it does not answer my questions:
1. Is there any minimal width for RESET_N in terms of clock cycles?
2. Should assertion of CLKEN always precede the RESET_N de-assertion (reset release)? if so, by how many clock cycles?
3. Are there any additional requirements for timing for RESET_N (e.g. should it de-assertion be synchronized to the clock of the NCO)?
In the lab, I observe that Enabling the NCO after reset de-assertion has a non-deterministic effect on the NCO output – after such reset the NCO initial delay (reset/Clken -> DV_OUT) is non deterministic.
Thus the questions is, what is the correct order/way to reset and then leave the reset for the NCO.
--Reuven.
