NCO IP (altera_nco_ii) "failed to initialize device database" on Quartus Prime Pro 20.1
I created an empty project for a Stratix 10 SX 1SX280HU1F50E2VG device using Quartus Prime Pro 20.1 on RHEL 6 host. I then created an NCO IP with settings that worked fine under my 19.1 project. When I attempt to generate HDL for this IP, the following error is reported:
Error: nco_ii_0: Problem getting the aliases for all known families com.altera.infrastructure.devices.DeviceDBException: Could not execute query: SELECT fam_alias.alias, fam.display_name FROM family_alias fam_alias JOIN family fam ON fam.id == fam_alias.family_id union all select name, display_name from family union all select display_name, display_name from family; com.altera.jdbcsqlite.Exception: no such table: familySee complete attached log. Any ideas how to fix this?
Hi Paul,
The workaround at the moment would be the generate the IP in 19.4 and use the RTL generated in your 20.1 Quartus release.
We are sorry to inform this. Currently, we are working on this and will file a kdb/documentation on this as well.
- KennyT_altera
Hi Paul,
