BHoey
6 years agoNCO Generation fails in QPro v20.1 with an error.
I've got v20.1 pro installed with just the Arria 10 devices. As a test I ran the NCO IP with just the defaults. These are messages from the Platform Designer generation : Info: qsys-generate D:\t...
KennyT_altera
6 years agoCan you try to install all devices? This seems to be a bug that need all device to be install.
Also, may I know what OS that you were using?
- BHoey6 years ago
Installed all other Devices (40GB worth) and still have the same issue. Tried the FFT as well and it was fine. Changed devices to C10 and had the same issue.
