Native PHY Reference clock with SSC enabled
Hi HPB,
As I understand it, you would like to feed refclk with SSC for the A10 TX. You are not concern about the ppm violation at the A10 RX side. For your information, if you can ensure that the SSC is within the datasheet spec of "Spread-spectrum modulating clock frequency" and "Spread-spectrum downspread" for PCIe mode, there should be no issue with the TX and ATX PLL. I observe your specs seems to be within the specs. Note that you should perform thorough validation to ensure the functionality is meeting your expectation since using SSC for non-PCIe mode is something not validated and not a normal supported feature.
Chee Pin
That means I can connect SSC enabled clock to Transceiver reference clock, but the clock's frequency variation must be within +/-300ppm wrt specified frequency.
(for example, 156.25MHz +/- 300ppm, this varied ppm can be due to SSC down-spreading )
With regards,
HPB
