S10PCIE
7 years agoMultiple BARs on Stratix 10 PCIE IP
Do you have any error report when you use multiple BARs of "Stratix 10 Avalon-MM Interface for PCI Express Solutions" of Quartus prime pro 17.1 ? We try to use BAR0 and BAR2 on "Stratix 10 GX FPGA De...
Nathan_R_Intel
Contributor
7 years agoThere is no error reported when using multiple BARs on Stratix 10 AVMM for Quartus Prime Pro 17.1.
All known issues are captured in the following page:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/kdb-filter.html
As you mentioned you are able to write to BAR0 successfully. Hence, I am suspecting either you are not accessing the BAR address correctly or using burst mode. If burst mode is enabled; then you will need to "Enable burst capability for RX Avalon-MM BAR<n> Master ports."
Please advice if you are performing the above.
