hostOccasional Contributor1 year agoMulti-rate Ethernet Byte order The Multi-rate Ethernet IP for Arria V uses a 2 byte data bus. Is the first word of the packet contained in bits 7:0 or is it in bits 15:8 ?
Recent DiscussionsNeed a AMI Ibis for GXB on a 10AX115N3Agilex-5 supported TransceiversLooking for example testbench for Cyclone-V Transceiver Custom_PHY IP from UG-01080-1.7Agilex™ 7 I-Series FPGA Transceiver SoC Development Kit GSRD BuildTranceiver Enhanced PCS Basic mode questions
