TKapi
7 years agoModular ADC core Intel FPGA IP ANAIN1 only (pins Channel 1, 2...TSD using as GPIO)
Dear, I want use Modular ADC core Intel FPGA IP. But ANAIN iput only (10M08SAE144I7G). Another ADC pins (Channel 1, 2...TSD) not, this pins are used as GPIO. Error (176310): Can't place multiple p...
Rahul_S_Intel1
7 years agoHi,
In Max 10 with part no: 10M08 devices from Intel quartus 14.1 restriction are been places, the package for your device is E144 , if you are ANAIN1 or ANAIN2, the restriction will be applied (page no: 32) that is the reason for the fitter error.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_gpio.pdf
Kindly follow the guidelines mentioned above to avoid fitter error.
Rahul
