12 years agoModify Ariia V ALTLVDS_TX data rate during work
Hello everyone, I'll try to explain the issue as clear as I can. I have a block which can operate at 2 different clock rates : 162 MHz and 270 MHz. I need to use ALTLVDS_TX with serialization ...
12 years agoThank you for the quick reply!
Just to clarify something. I'm thinking of using a "master PLL" to generate 2 clocks : 162 MHz and 270 MHz for the logic blocks. those 2 clocks will go through ALTCLKCTRL and only one will act as the system clock . 1.Can I use this clock as reference clock of the ALTLVDS PLL? (which in turn will produce x10 serial clock) 2.What do you mean "high-speed serial I/O" ? (is it an IP i can instantiate ) Thanks again
