AVovk
6 years agoModelsim error on altera_onchip_flash_block - Error: (vsim-3033): Instantiation of 'altera_onchip_flash_block' failed. The design unit was not found.
Hello. I'm trying to simulate project with getting data from OnChipFlash. I'm using the Lite edition of Quartus 17.0.2 and ModelSim - INTEL FPGA STARTER EDITION 10.5b. I create testbench file to s...
- 6 years ago
You make the AC_meas_tb as the testbench. Can you check inside the AC_meas_tb.v files, what is your module name there? currently, the tools are complaining the testbench issue.
AVovk
6 years agoI searched the Internet for an example of working with Flash memory, thinking that there was a mistake somewhere in my project and therefore FFFFF was always read from Flash. On FpgaCloud, I found a project like this:
I started the simulation and saw that FFFFF is always read from Flash. This project was created by Altera (Intel), I am sure that there is no error in it.
Why is FFFFF always read from Flash?
PS I am using Quartus 17.0.
