Modelsim error on altera_onchip_flash_block - Error: (vsim-3033): Instantiation of 'altera_onchip_flash_block' failed. The design unit was not found.
- 6 years ago
You make the AC_meas_tb as the testbench. Can you check inside the AC_meas_tb.v files, what is your module name there? currently, the tools are complaining the testbench issue.
Again the problem.
Data from flash memory is not retrieved, data is always in logical 1.
Modelsim writes the following in log:
# ** Warning: (vsim-3017) ./../submodules/altera_onchip_flash.v(297): [TFMPC] - Too few port connections. Expected 18, found 17.
# Time: 0 ps Iteration: 0 Instance: /AC_meas_tb/main_inst/sin_data/onchip_flash_0/altera_onchip_flash_block File: nofile
# ** Warning: (vsim-3722) ./../submodules/altera_onchip_flash.v(297): [TFMPC] - Missing connection for port 'bgpbusy'.
# ** Warning: (vsim-3017) <protected>(<protected>): [TFMPC] - Too few port connections. Expected <protected>, found <protected>.
# Time: 0 ps Iteration: 0 Protected: /AC_meas_tb/main_inst/sin_data/onchip_flash_0/altera_onchip_flash_block/<protected>/<protected>/<protected>/<protected>/<protected>/<protected> File: nofile
# ** Warning: (vsim-3722) <protected>(<protected>): [TFMPC] - Missing connection for port '<protected>'.
These are the only compilation warnings.
All data is protected. Therefore, there is no retrieval of them?
