AVovk
6 years agoModelsim error on altera_onchip_flash_block - Error: (vsim-3033): Instantiation of 'altera_onchip_flash_block' failed. The design unit was not found.
Hello. I'm trying to simulate project with getting data from OnChipFlash. I'm using the Lite edition of Quartus 17.0.2 and ModelSim - INTEL FPGA STARTER EDITION 10.5b. I create testbench file to s...
- 6 years ago
You make the AC_meas_tb as the testbench. Can you check inside the AC_meas_tb.v files, what is your module name there? currently, the tools are complaining the testbench issue.
AVovk
6 years agoThanks a lot KennyT_Intel!
You are a very attentive, but I am not at all! If it weren’t for you, I wouldn’t notice the difference between MAES and MAIN in "AC_xxxx_tb", because they are so similar among a huge number of letters!
