AVovk
6 years agoModelsim error on altera_onchip_flash_block - Error: (vsim-3033): Instantiation of 'altera_onchip_flash_block' failed. The design unit was not found.
Hello. I'm trying to simulate project with getting data from OnChipFlash. I'm using the Lite edition of Quartus 17.0.2 and ModelSim - INTEL FPGA STARTER EDITION 10.5b. I create testbench file to s...
- 6 years ago
You make the AC_meas_tb as the testbench. Can you check inside the AC_meas_tb.v files, what is your module name there? currently, the tools are complaining the testbench issue.
KennyT_altera
6 years agoYes, some of the IP component use platform designer format. If use megawizard/megafunction it is still fine.
Anyway, I look into your .v files, it
AC_main_tb which is not AC_meas_tb, you may need to change it.
