AVovk
6 years agoModelsim error on altera_onchip_flash_block - Error: (vsim-3033): Instantiation of 'altera_onchip_flash_block' failed. The design unit was not found.
Hello. I'm trying to simulate project with getting data from OnChipFlash. I'm using the Lite edition of Quartus 17.0.2 and ModelSim - INTEL FPGA STARTER EDITION 10.5b. I create testbench file to s...
- 6 years ago
You make the AC_meas_tb as the testbench. Can you check inside the AC_meas_tb.v files, what is your module name there? currently, the tools are complaining the testbench issue.
KennyT_altera
6 years agoPS If I start RTL simalation from Qaurtus I get error "Error: (vsim-3033): Instantiation of 'altera_onchip_flash_block' failed".
do not use this method, this method is not for platform designer usage.
- AVovk6 years ago
Do I understand you correctly that running a simulation through Quartus (Tools-> Run Simulation Tool-> RTL Simulation) is possible only if there are no IP components? As soon as the IP component is included in the project, the start of the simulation is possible only through manually editing a file "msim_setup.tсl and further execution of the LD command. The only way?
