KJame6
7 years agoMicron MT25Q flash support query
I see that Quartus v18.1 now includes Micron flash options in the ASMI_PARALLEL, ASMI_PARALLEL_II, and SERIAL FLASH LOADER IP cores. I use the ASMI_PARALLEL IP core in my design, specifically. Thes...
JohnT_Altera
7 years agoHi,
There is no way to use same design for BOTH flash device. The reason is that both flash is not identical and there might be issue happening if you are using the same file.
